| Posted by Gene Holmerud on June 06, 2001 at 00:46:27: | |
| In response to Re: Mixet shower valve temperature adjustment | |
: : The temperature adjustment lever should regulate it since it shuts off the hot water flow when it is rotated to the cold side. : That's what I would have thought, but it doesn't appear to be doing that. Is this perhaps a bad cartridge, or some such? I've got the same problem after 2 replacements! The temp varies from day to day, but on a given try, rotating the temp lever has no effect. Is there something to replace other than the insert (package replacement sold at Home Depot, etc.)?
