| Posted by todd on June 01, 2001 at 05:50:31: | |
| In response to Re: Low Water Pressure | |
: Sean, : the water regulator on your holding tank must come on at 30 psi and run to 50 psi then shut off.buy a big blue water filter and install it inline before your holding tank to catch sediment,you may very well have a clog in the system.Also maybe your well is not giving you a good flow in the ground or your pump in the ground is under sized it has to lift that water from your well depth ,how deep is your well? start in the ground and and check that pump first |
| There are none. |
