| Posted by Mike L. on November 12, 1998 at 09:41:31: | |
| In response to Re: Replacing pipe to ceptic system | |
:Correction to previous question: I need to replace the main drain pipe from my house to my CESSPOOL. The pipe I'm replacing is old clay type. Do I use regular PVC or is there another type I need to use? Also, if I do use PVC do I use PVC cement to connect the pieces? The main pipe which comes from the house is cast iron. I assume I use a rubber coupling to connect to the new pipe that I will be using. Thanks in advance.
