| Posted by Mike L. on November 12, 1998 at 09:37:06: | |
I need to replace the main drain pipe from my house to my ceptic system. The pipe I'm replacing is old clay type. Do I use regular PVC or is there another type I need to use? Also, if I do use PVC do I use PVC cement to connect the pieces? The main pipe which comes from the house is cast iron. I assume I use a rubber coupling to connect to the new pipe that I will be using. Thanks in advance. |
