| Posted by Mark Bluestein on May 23, 2001 at 11:53:27: | |
| In response to Re: Q-Any further info of Eljer AquaSaver perform? | |
: : Hi Terry, : : 1-this board is great. thanks! : : 2- Q- Do you have any further performance info of the Eljer : : Any further info/recommendations from anyone? : : Thanks for a great source of info, : : Thanks, : Bruce W. After a year of regular use I've been very pleased with my unit. The flush is very powerful and quieter than the Flushmate. Initially the tank/bowl gasket leaked, squirting out a stream during the high pressure flush. Eljer sent me a new gasket with a different hardness and I carefully aligned the tank and torqued the bolts. You have to be careful you don't apply too much pressure to the bolts which could crack the bowl unit. My plumber who initially installed the toilet wasn't familiar with pressurized systems and quickly gave up trying to fix the leak. A real advantage of the Aquasaver is that the water surface covers essentially the entire bowl, keeping the bowl clean. Haven't had the problem that Terry mentioned about shredding of toilet paper. Contents of the toilet seem to vanish instantly as soon as you flush. Check out the PF2 website for all kinds of technical info on the pressurized system. (www.pf2wctc.com) Mark Bluestein
| There are none. |
