Re: kitchen remodeling
Posted by Grout Guys; Phoenix on November 11, 1998 at 23:35:32:
In response to Re: kitchen remodeling
: : The next solution you might consider is re-grouting. This process involves the removal of the existing grout with a tool such as a "grout saw" or a carbide tipped tool called a "grout getter". These tools are available at tile stores or your local home improvement center. The work itself is time consuming, as you must scrape as much grout from the joints as possible. Care must be taken at the intersections of the tile, as chipping or cracking might occur. After you have removed 1/8 to 1/4 inch of the old grout, you can re-grout the lines with the color of your choice. Although this job is something that the "do-it-yourselfers" can tackle, you may want to check the local phonebook under "tile". Most areas have at least one company familiar with re-grouting. Good Luck !
Replies to this post
There are none.
