Re: Satellite TV Installer Drilled Through Plumbing Pipe
Posted by Tom on May 10, 19101 at 00:50:05:
In response to Re: Satellite TV Installer Drilled Through Plumbing Pipe
I believe its a drain pipe (installer reported water on drill bit). I assume this is "worse case" than a vent, but what are we facing (it's a vertical pipe, so I'm assuming quick water flow through it). Thanks!
: Was it a drain or vent pipe? Depending on what kind of sleeve he installs, it could be a permanent fix.
: : We just had a satellite TV system installed in our home and the installer managed to drill through both sides of a plastic drain pipe. His company is going to get a plumber to repair it, ostensibly by installing a sleeve over the damaged area. My question is "what is a satisfactory fix in this type of situation?" I don't want a leaking pipe several months or years in the future. Any advice about what we should look for? Thanks.
Replies to this post
