| Posted by hj on May 10, 19101 at 00:07:00: | |
| In response to Re: How can i test a control valve on a Water Heater | |
If you mean the thermostat, check the water temperature with a thermometer. If you mean the safety relief valve, pull the lever up and then see if it shuts off when you let go of the lever. : Hi, I was Just wondering if there was any way of testing a control valve on a water heater to see if it is bad. Thank You Jason
| There are none. |
