Re: Electric Dryer Vent
Posted by Chris on May 05, 19101 at 03:15:37:
In response to Re: Electric Dryer Vent
: Hello. I have a flat roof house with an electric dryer on an inside wall. I have no way to vent it to the outside. If I don't vent it at all, my walls get wet and this won't do. I am currently using a long vent hose connected to the back of the dryer that I stick out a window when the dryer's running. It's pretty pitiful, but it works. Any suggestions as to how to permanently vent this dryer? Is it safe to go to the chimey of the woodstove and run an aluminum pipe up the chimney? Would I have water running down the pipe if I vented through the roof (about 8'). thanks for your help!
If you have not yet fixed your dryer vent problems, then try this one.
Go to Lowes or the Home Depot and purchase a self contained vent system for your dryer.
This system mounts to the wall close to your dryer. You the fill it with water and connect the hose. It not only contains the excess lint, but also helps to control the condensation.
Replies to this post
There are none.
