Hot Water Heater Rusting at Bottom
Posted by Scott on May 03, 19101 at 21:52:20:
I am an FHA Real Estate Appraiser. I have inspected a home with an electric water heater in the garage, which sits on a concrete slab. The bottom of the water heater is starting to rust. Do you know if the water heater itself is rusting or is because the water heater is sitting on the concrete slab? How do I know how much life the water heater has left? Is this a serious problem which will cause the water heater to fail to operate? Please help if you can. Thank You
Replies to this post
There are none. |
