Re: toilet tank leaks a lot out onto floor
Posted by hj on May 02, 19101 at 09:20:13:
In response to Re: toilet tank leaks a lot out onto floor
That is usually the first incication of an obstructed sewer pipe. If you were around here, I would guess roots have grown under the floor, up around the toilet pipe, and into the pipe from between the toilet and flange, obstructing the flow from the bowl and causing the leakage.
: How do I stop the toilet tank from leaking? It seems to be leaking from the place where it connects to the bowl, or else from the bolts. It floods the bathroom floor.
Replies to this post
There are none.
