| Posted by hj on May 02, 19101 at 09:17:41: | |
| In response to Re: Broken Moen Cartridge | |
There are three other removal tools that a good plumber will have to finish the removal. Your experience is a common one using the tool you had. But it is always the first step regardless of which other tool is required to finish the removal. : Boy, am I in trouble. While replacing the standard Moen single handle cartridge (which I have done successfully before) using the cool little removal tool and everything, I somehow pulled out only the interior of the cartridge, but not the brass outer cartridge. Then, trying to grab it with needle-nose visegrips by the little brass flanges that protrude, I ended up pulling those off too. That baby seems to be corroded in there pretty tight. I tried WD-40, of course, before destroying the little flanges, but to no avail. Am I gonna have to completely pull out my fiberglass shower stall and replace the pipe that the cartridge sits inside? Geez, I hope not. HHHEEELLLPPP! : PS - The water is off till I can fix this one.
| There are none. |
