Re: installing a wall mounted toilet
Posted by hj on April 30, 19101 at 00:05:57:
In response to Re: installing a wall mounted toilet
There is a big difference between a floor mount and a wall mount. The piping in the wall that supports the toilet will automatically ensure that it is level when the mounting hardware is installed correctly. The syphon function is built into the bowl. If you do not install it level there will be a gap between it and the wall. You should be talking to a local plumber not HD or Lowes.
: I am installing a wall mount toilet in my house.
: are there any special instructions that differ from floor mount models?
: how crucial is leveling the toilet from front to back?
: will i have siphon problems if i dont get the sucker to sit perfectly level?
: nobody at lowes or home depot knew anything about wall mount
: thanx
Replies to this post
There are none.
