Re: replacing water supply line from house to meter
Posted by hj on November 10, 1998 at 20:24:56:
In response to Re: replacing water supply line from house to meter
A sweat female adapter at the meter, and soldered right to the pipe from the house, (or with a union), and a shut off valve in the line.
: my house was built in 1956 and had all galvanized pipe. I have replaced it all with copper. I could hear what sounded like water running but couldn't find any leaks. Ifinally traced it to a break at one of the joints in the supply line comming from the meter, a tree root had pushed up on it and cracked it. I have dug up the line from the meter to the house and am ready to replace it with copper. My concern is how i figure the type of connectors to use and what diameter pipe.
: Any help you can give will be greatly appreciated.
: Thanks
Replies to this post
