| Posted by hj on April 27, 19101 at 11:00:55: | |
| In response to Re: bathtub leak | |
I assume this is a pressed steel tub. If so, then the answer is no. There is usually not enough metal left after the rust finishes with it to make any kind of permanent repair. : Does anyone have advice on how to repair the metal portion of the bathtub around the drain?
| There are none. |
