| Posted by Chuck on April 26, 19101 at 21:00:06: | |
| In response to Re: tub leaks underneath | |
Does it leak to the floor below or is it on a slab? Most likely a drain problem. If the water cannot drain below it will come out the sides. Copper piping doesn't go bad too often, unless you have old gavanized which may also be the problem. Just my 2 cents worth. : Help! Why would our tub leak from the grout next to the tub. At first it seemed to only do this when the facuet was running the the plug was stopped. Then it stopped all together. Now it is doing it when the showerhead is on the the plug not stopped.
| There are none. |
