| Posted by Clint Whetzel on April 26, 19101 at 19:42:40: | |
| In response to Re: Moen shower handle breaks | |
: We have had a Moen shower handle for the past 2 years, it was here when we moved in and it worked : fine in that time frame, until about a month ago when it broke in the center part. We have replaced it : about two times since but it always breaks in the same place. Which is where the plastic handle is : screwed into and goes onto the metal part in the wall. The replacements have worked fine for several : days but then break in the same place. The first time with the original I beleve was old age, the second : I think may have been because the white plastic part was not around the metal stem in the wall. The : third time I thought that the screw might be too tight. I do not know anything about these things and : need some help in laymans terms. The part number on the box is 96884 but I was unable to find it on : the Moen site. sorry the part number was wrong on the original : Thank You.
| There are none. |
