| Posted by outofplumb on April 21, 19101 at 21:43:45: | |
| In response to Re: closet flange broken | |
: : i have a closet flange that is broken on one side. the : : broken part is where the bolt fits thru. how is this problem corrected? flange is cast iron. manuel, this is an easy one, what you need is a spanner flange.the spanner flange will slip underneath the old flange, get a new set of closet bolts and wax ring. you might have to tap s.f. in with a cold chiesel and hammer. reset toilet and snug bolts do not overtighten or you will be repairing the other side. best of luck |
| There are none. |
