Posted by Rod R. Schurman, P.E. on April 21, 19101 at 09:19:00:
In response to Re: CPVC
As the fist reply says, check the supply line from the street first. There are pump systems you can use to boost the pressure.
Also, CPVC will not cause a chemical odor in the water. It is specifically designed to not put anything into the water, which is why you can't use basic PVC for water lines. I suspect the water softener.
Replies to this post
There are none.
