| Posted by Rod R. Schurman, P.E. on April 21, 19101 at 08:58:37: | |
| In response to Re: underground copper pipe corrosion | |
Copper is �typically� the best metal for burial, but it is still susceptible to corrosion. The green and maroon discoloration is typical for buried copper pipe, but the complete corrosion indicates a problem. Grounding to the water pipe can cause corrosion given the right soil conditions. Never ground to the water pipe. Check your pipes and remove any ground clamps you find. Connect instead to a buried ground-rod (available at hardware stores). You may also have corrosive soil. You may be able to use an anode or similar device to prevent A new (15 years) plastic pipe that solves corrosion problems is called CPVC. It is specifically |
| There are none. |
