| Posted by hj on April 17, 19101 at 09:06:39: | |
| In response to Re: LOW HOT WATER PREASURE | |
In that case, it has to be somewhere common to the whole system. The water heater shut off valve is the most likely reason. Either it is broke or not open entirely. : I have low hot water preasure thru the whole house.The home is only 2 1/2 years old.There seems to be no problem with water preasure for the cold water.
| There are none. |
