| Posted by hj on April 15, 19101 at 22:14:56: | |
| In response to Re: Oil Burner & tankless hot water - temperature settings? | |
If the system can heat the house at the new settings then your fuel bills should not change. The water temperature should be controlled by a mixing valve set to the desired house hot water temperature. : Hi. I have an oil furnace/burner that uses forced hot water baseboards. My hot water comes from a tankless : Is this a problem? Have I diminished the furnace efficiency? How is the household hot water temperature : Any help would be much appreciated. Please send EMAIL to ruston@townisp.com also with any replies. Have
| There are none. |
