| Posted by Dewey E. Fox on April 12, 19101 at 08:56:20: | |
I'm a homeowner, finished contructing my home October of last year. About 30-45 days ago a odor started coming from the drain in one of our sinks. We are on a septic tank type system. All the other sink drains are ok. Called my plumber, he advised that the odor could not come out of drain as long as there is water in the drain pipe going out of the sink. (but is does) try brushing your teeth early each morning with this odor coming out of drain into your face. I took the drain pipe loose one evening after letting the sink set all day and there was water in the drain. I also filled the sink with water and let it set for 2 days and there did not seem to be any odor coming into the bath. Any suggestions from anyone. thanks, Dewey E. Fox
| There are none. |
