| Posted by hj on April 12, 19101 at 08:48:43: | |
| In response to Re: LP Gas line for a Outside Grill | |
Unless you install a second regulator at the grill, you will want to connect after the second stage regulator at the house. As far as the actual pipe installation, especially since it is LP gas, I would recommend having a plumber install it. He will know what is approved and the best for your area. : I want to hookup my outdoor gas grill to a 200lb tank that I have for a basement heater. I need to run the pipe underground approx 35 feet. and was wondering what would be the best way to do that. I need to know the i.d. of the pipe and what material to use. Would the pressure reducer on the 200lb tank be ok, etc. Our area has very liberal enforcement of codes but I do want to be safe.
| There are none. |
