| Posted by Henry Raynor on April 10, 19101 at 16:27:12: | |
My contractor re-plumbed my home with copper except for the galvanized steel stand pipes that go up to the faucets. He put a brass fitting between the copper and galvy steel. Is this an acceptable method to avoid rapid corrosion between the copper and steel? Is lead in the brass likely to leach into the water? Thanks in advance for the help. Henry Raynor |
| There are none. |
