Re: maytag dryer won't run
Posted by hj on April 07, 19101 at 15:22:00:
In response to Re: maytag dryer won't run
There can be several possibilities. One side of the power may have failed for some reason. There could be another switch that is defective. You need someone to check the circuits with a tester rather than just guessing what the problem is.
: My maytag dryer shut off in the middle of a drying cycle and hasn't turned on since. You can here the timer clicking but the dryer will not turn on. The light inside does not go on when the door is opened. I thought it was a faulty door switch and replaced it. The problem still exist. Any suggestions would be welcomed!
: Thank-you Jill
Replies to this post
There are none.
