| Posted by Keith L. on November 09, 1998 at 08:09:16: | |
| In response to Re: JACUZZI SPA | |
Another thing you might want to check is the "low" water sensor. Many whirl pool tubs have these so the pump isn't run dry. The one on mine is located about 2" above the one jet, it's a silver button about the size of dime. You may have to lift the tub out to get at the backside of this or if your lucky you can access it from the basement or an access panel. Good Luck.
| There are none. |
