Re: Water heater reset button
Posted by hj on March 31, 19101 at 23:11:01:
In response to Re: Water heater reset button
Before you change the thermostat, or anything else, find out what the problem is. The most likely problem is a burned out lower element which has bypassed the thermostats and therefore overheats the water.
: The reset button on my water heater has tripped 5 times in the last 3 days. I'm going to change the thermostat but is there anything else I should be concerned about?
Replies to this post
There are none.
