| Posted by Jean O'Leary on March 29, 19101 at 08:57:38: | |
| In response to Re: Need Tub Drain Advice | |
I am trying to replace the bathrub drain. The drain broke off inside the tub. How can I get it out? Thanks for your help. Jean O'Leary
: Any suggestions? I'll try reinstalling this and then I'll probably check a brass drain/overflow to see if I can rotate the elbow before I install the nipple onto the elbow, but I'm wondering if there's a drain/overflow available that secures the drain to the elbow some other way, like with a nut from above on a stud inside the elbow. : This is for National fiberglass tub. Enlarging the concrete recess would be a last resort as the tub is on a mortar base. : Thanks for any suggestions. : John Grimmer
| There are none. |
