| Posted by Terry Love on March 28, 19101 at 11:58:51: | |
| In response to Re: wet floor | |
![]() : Terry, the carpeted room next to the laundry has half of the rug in it wet .Can you tell me what my next step would be to stop this leak. The walls seem to be dry . Also how much damage can I suspect from the plumber with in reason Bobby, Did the hose jump out of the drain during it's cycle. When water starts pumping, it can lift up the hose and miss the drain. Does the floor dry up when the washer is not in use? Is the leak constant? A constant leak would indicate a leak in the supply piping.
| There are none. |
