| Posted by Dan on March 23, 19101 at 10:14:16: | |
| In response to Re: Oil Furnace Black Smoke | |
Where can I find the specs on oil burners (furnace). I can see I'm getting enough air so my nozzle tip must be open or worn. The pump is 100 psi. Rated .4 - 3.0 GPH. The nozzle is marked 100 70%. Do these things wear? or open wider with use? Thanks to all Dan
