| Posted by hj on March 21, 19101 at 23:49:16: | |
| In response to Re: fixing a broken copper pipe | |
Fixing the pipe is not going to be as much of a problem as getting a fitting to fit. If the pipe froze, 99% of the time it also swelled up at the freeze and fittings will not fit the new size. If the freeze was bad enough, the entire pipe could be oversized. : Hi, : I was wondering if there was a way to fix a broken copper pipe without soldering it, or am I going to have to replace it and solder it in place again. It was frozen and broken in the middle of the pipe and isn't leaking near a joint as far as I can tell. : Thanks
| There are none. |
