Re: Insinkerator stays on
Posted by hj on March 19, 19101 at 07:57:16:
In response to Re: Insinkerator stays on
You can try moving the switch in and out or back and forth, depending on which you have, to try and free up the mechanism. It has corroded or material has built up around the shaft so it cannot spring back by itself. Moving it back and forth may loosen it up enough so that it can function properly.
: I have a batch feed Insinkerator that stays on. I can remove the stopper that turns it on and off, but it still keeps running. I now have to use the disposal by tripping the breaker in the basement. Is there a simple fix here, or do I need to replace it? Thanks in advance.
Replies to this post
There are none.
