| Posted by Chuck on March 15, 19101 at 09:10:56: | |
| In response to Re: toilet leaking | |
Did you replace the gaskets? Most toilets have gaskets on the screws that hold the tank down. : I took the tank off of the bowl to paint and when I put it back on it leaked. It is leaking from the bolt that screws the tank and bowl together. I bought new bolts with washers and it is still leaking from one of the bolts. Do I need to use some kind of plumbers putty or anything? Any help would be appreciated. Thanks so much! : Jen
| There are none. |
