| Posted by hj on March 14, 19101 at 23:46:50: | |
| In response to Re: Kohler rite-temp pressure balancing valve | |
The shower head will restrict, (by its design, not a restrictor), either to exactly the same flow. If you were to have several body sprays in the shower, then you would need the high flow version. : A 1/2 inch copper pipe will supply the shower valve which I'm about to buy. My choice will be either Kohler's basic 304-K, or the "High Flow" version 306-KS. I plan to keep my 22 year old Kohler Alterna showerhead(no restrictor) and would like an opinion on whether the "High Flow" valve wil actually deliver a stronger water flow through the showerhead than the basic rite-temp pressure-balancing valve. Any info will be greatly appreciated.
| There are none. |
