| Posted by Sleepy on March 14, 19101 at 02:05:56: | |
| In response to Re: Replace Oil Furnace | |
I've never heard of a stand alone, oil hot water heater. Has the system ALWAYS supplied scalding water? If so, maybe that's the way it was designed. If not, one of the controls is probably bad. Given the price of gas, I personally would stick with oil for heating. Electricity has been stable in price, so an electric hot water heater might not be a bad idea, unless you live in the Northwest. Then, you could just shut off the hot water part of your system. Does the boiler have to run all summer, so that you have hot water? If so, that may be the cause of the problem. It may not be cycling correctly into it's summer mode. Is there a summer and winter setting, and do you have that set correctly?
: Thanks,
| There are none. |
