| Posted by Sleepy on March 14, 19101 at 01:23:41: | |
| In response to Re: water heater needs constant resetting sometimes | |
I would guess one or both thermostats is sticking open or the contacts are burned. Check for telltale soot or melted plastic on the thermostats. Also look for discolored wires which would indicate overheating due to high resistaance(burned contacts). The lower element could also be burned out, especially if when you do have hot water, you run out quicker than you should. Thermostats and elements are not very expensive. My water heater needs to be reset constantly, I can hear it running and have to go and push the reset
| There are none. |
