Re: toilet flushes only second time
Posted by Sleepy on March 14, 19101 at 00:49:37:
In response to Re: toilet flushes only second time
I believe the Fluidmaster has a spring clamp that allows you to adjust the level of water in the tank. Adjusting it to a higher water level may solve the problem. : i just installed a fluidmaster "overhaul" package and the water is lower than normal in the tank and bowl. that's fine, but the first flush it just fills the bowl close to the previous level (before fluidmaster) but never flushes. if i press the lever to flush again all of the water goes out like is supposed to. repeated again several times and still fills back to low level, never flushes first time but puts more water in bowl and goes down the second time. : thanks for any help. : derek
