| Posted by hj on March 11, 19101 at 17:27:37: | |
| In response to Re: Spartan Shower | |
All the screws are installed from the top. The bottom strip is probably glued/caulked to the shower base. : I didn't htink it was going to be that difficult removing a shower door so I could re-caulk as it's leaking. : Everything comes apart nicely except when I go to try to remove the bottom tracking that's connected to the plasic base of the shower. There was a screw that was removed, but it appears that it's still fastened securely to the base. Do they usually screw in from the bottom as well? Do I have to remove the base/doors to get at the bottom? : Just trying to get by with the least amount of work!
| There are none. |
