| Posted by Dean Smith on March 09, 19101 at 12:35:23: | |
| In response to Re: Bathtub water valves | |
Probably buried in the wall behind the tile, or, if you're lucky, behind the drywall near the tile. BUT, lots of valves, especially newer ones, have shutoff valves BUILT IN to the handle/valve mechinism. Remove the handle & the trim around it, and you may find two screws w/ both screw notches facing the same way (usually horizontal) These are the built in shutoffs-turn each 90 deg. and you will stop the water from entering the valve & fix your leak. : I live in a condo/apartment, where would I look to turn off the water valves so that I can fix a leak in my bathtub faucet?
| There are none. |
