| Posted by Lee on March 09, 19101 at 02:34:59: | |
| In response to Re: garbagedisposal | |
With the power OFF and unplugged/disconnected if possible, look into the drain hole and see if anything appears to be caught in the blades. Use the wooden end of a broomstick or something similar to push the blades around a bit. Then look for a reset button on the underside of the disposer and press it. If there is a socket for a hex driver/ Allen wrench on the center of the disposer's bottom, insert the wrench and twist it back and forth. Run water and try using the disposer again. : I aciendently chopped up a shot glass ,and ever since the dam thing won't come on. It's like there's
| There are none. |
