| Posted by D.S. on March 09, 19101 at 00:35:56: | |
| In response to Re: crane vs gerber | |
The Gerber Ultraflush will probably only be found at a plumbers suply house. Whereas the Crane Economiser can be found at most hardware stores(i.e. Lowes). There is not much, if any in price difference between the two. I have installed the Crane in my house. The flush lever take some getting used to because of the location. I have never had to use a plunger to clear it out and am very happy with the flush. I would even be willing to bet that it would out perform an older 5 gallon flusher. If you are still unable to find the Gerber locally, You should be able to order it from this website. |
| There are none. |
