| Posted by Harold on March 07, 19101 at 05:57:35: | |
| In response to Re: Leaking Delta kitchen faucet | |
: I assume you did not change the ball, and also that you have a plastic ball. If either or both of these apply to you, change the ball. : : I have a single handle Delta kitchen faucet that is leaking. I received a repair kit from Delta and I installed it. However, it still leaks. I can fool with the handle to make it stop leaking, but, of course, that isn't the solution. (I have to do this every time I turn off the water.) What else can I do?
| There are none. |
