Re: Leaking Delta kitchen faucet
Posted by Roger Eastin on March 06, 19101 at 08:27:41:
In response to Re: Leaking Delta kitchen faucet
: I assume you did not change the ball, and also that you have a plastic ball. If either or both of these apply to you, change the ball.
: : I have a single handle Delta kitchen faucet that is leaking. I received a repair kit from Delta and I installed it. However, it still leaks. I can fool with the handle to make it stop leaking, but, of course, that isn't the solution. (I have to do this every time I turn off the water.) What else can I do?
I have a metal ball, but I did not replace it. Is that something I can get at Lowe's or do I have to get one from Delta?
Replies to this post
There are none.
