| Posted by Gary on March 04, 19101 at 02:16:53: | |
I have a 15 year old house & just recently the cold & hot water pressure to the bathtub spouts have been drastically reduced to almost a trickle. It takes approximately 1/2 an hour to fill the tub. I have copper pipes not galvanized, I had a new water heater installed about 4 years ago & haven't had any work done to the water heater since the installation. I get my water supply from the County not a well. I've replaced the spouts(faucets) once myself without any success & then I had a plumber replace the spouts, again without any success. The second plumber inspected the spouts & had no clue as to what was causing the problem. The pressure to the shower heads are better but less than the rest of the house. And the pressure everywhere else in the house is fine. The spout is the type that you pull out (towards you) & turns one way for the hot,the other way for the cold water & you have to pull the diverter up in order for the water to go to the shower head. Since the pressure is low for both hot,cold & only effects the bathtub spouts & no other faucet/spout in the house. Does anyone have any ideas of what could be causing this & is there anything I can do besides tearing down the wall & replacing all the pipes? Any help,suggestions,ideas would be greatly appreciated. Thank you |
| There are none. |
