Re: Leaking Hot Water Heater
Posted by paul on March 04, 19101 at 02:05:33:
In response to Re: Leaking Hot Water Heater
It depends on where the leak is. If either the pop off valve or the drain valve is dripping, then these can be fixed. Also, if there is water leaking around the seal of one of the heating elements, the gasket can be replaced. Is it possible you are getting a large amount of condensation on your cold water pipes which appears to be a leak when it drips off? Insulating those pipes would cure it if that was the problem.If however, the leak is around the pipe fittings, or the tank itself, then you definitely will need to replace the water heater. Most water heaters have about a 10-15 year warranty, I believe, and we all know that they are programmed by the manufacturer to fail immediately thereafter. :-) Be sure to follow all safety precautions when working on a hot water heater. You are dealing with 220 current and scalding water. : My hot water heater leaks a quart or two of water : usually in the winter when the teperature gets below : 20 degrees outdoors (and when the utility room where : it is located gets a little chilly). The unit is : about 12 years old. Is there a good chance the leak : continue to get worse and eventually flood my basement ? Thanks.
Replies to this post
There are none. |
