| Posted by hj on March 02, 19101 at 23:14:06: | |
| In response to Re: check valve | |
It could be if the system has a recirculating line and they are the last fixtures before it returns to the hot water heater. : We get hot water to two of our bathrooms while the other gets only lukewarm water. I have been told a bad check valve is the problem. Does that sound right to you? If so, how is it replaced? Thanks
| There are none. |
