| Posted by Sleepy on March 02, 19101 at 18:37:30: | |
When we moved in this house 15 years ago, we had them replace the floor pan of the walk-in, ceramic tile shower. The plumber connected the new drain to the old galvanized pipe with a piece of PVC pipe. Since then, we get a calcified deposit that gradually builds up inside the drain pipe, much like stalactites and stalagmites in a cave. I have to go in and scrape out the pipe every so often to keep the drain running. I assume this is some sort of static charge problem causing the deposit to form, I don't have this problem with any other drains. Is the PVC pipe the problem, and is there a solution, short of replacing it? Sleepy |
