| Posted by CM on March 01, 19101 at 08:14:49: | |
| In response to Re: Cast Iron Bathtub Insulating? | |
I'm assuming you have an alcove bath with an integral front apron. You can determine the required support height by setting the tub on the floor, and with the tub resting on the front apron, lifting the rear side until the tub is level front-to-back (determined with a carpenter's level on the tub). Then measure the height to the bottom of the surface at the rear of the tub that will rest on the horizontal support. You can wrap fiberglass insulation around the basin of the tub before installation.
: I am remodeling the bathroom in our home. : Thanks again,
| There are none. |
