Re: Cast Iron Bathtub Insulating?
Posted by hj on March 01, 19101 at 08:12:22:
In response to Re: Cast Iron Bathtub Insulating?
Measure from the floor to the bottom of the lip at the front of the tub. You could try coating it with spray foam, but since cast iron is so dense, you would probably be through with your bath before the heat penetrated it.
: Thanks for reading my question.
: I am remodeling the bathroom in our home.
: We are reusing a American Standard cast iron bathtub.
: We will soon be reinstalling the tub in to its spot.
: The tub will need to be leveled using 2X4's.
: How do you find out the proper height for the supports?
: Also, is there a way of insulating the tub to hold heat more efficiently?
: Thanks again,
: Eric, S.R. CA,
Replies to this post
There are none.
